783
1,204
TX
Any thoughts on tires for this build
Pretty sure I don't pass 😜
Right now I'm going with whatever I can get cheapest! ha Picked these up off a local gent that races GTD in IMSA for$100 a tire
I also have a pair of worn A7s from @flyhalf that came on a set of wheels I bought from @flyhalf.
783
1,204
TX
True. Whenever I’m at Road America, I have yet to see someone being sent home early because of sound limits.
I didn't realize RA has sound limits. Should I bring an alternate muffler setup?
783
1,204
TX
Finished up the radiator ducting yesterday. Happy with how it came out! If this works, I'll make out of CF in the future.
Sealed up against the radiator with window sealing foam. I've used this the past with good success. don't worry, it doesn't melt
To secure, I added a couple bolts to my modified k member on the bottom and then a couple into the mount for the upper radiator. Nothing crazy. Just enough to hold it in place
So while this is definitely cobble-fab'd together, it only weights like 2 lbs and my previous experience with making ducting out of this thin AL shows that it works great. So traded a bit of "build" quality for some lightness. Hopefully a CF unit the future will be much higher quality
783
1,204
TX
Any feedback available on any impact on power (positive or negative) after those Ti mufflers??
the Ti mufflers are straight through, so absolutely no impact on power unless you're using restrictive mufflers already. They're basically a light weight way to muffle sound. even the big mufflers won't impact power. They're truly amazing.
Only downside outside of how hard they are to weld is that they don't take the same quantity of heat cycles like stainless. so they can crack after a few years
6,580
8,243
This design has been around forever, what's new is the material. Much much lighter.
Dave_W
1,016
1,326
Ducting looks nice. If you're worried about the thin sheet "oil canning" you can do a poor-man's bead roll by laying it on a sand bag, putting a wooden dowel on top, and hammering the dowel to create a bead. A little bit of curvature from a bead puts a good deal of stiffness into a large sheet.
456
595
Wisconsin
They dont. My car is next level loud and I been there 3 times with it.
My bad, I misinterpreted a rule RA imposes on “their” track days that only allow street legal cars. I’m embarrassed to say something incorrectly as I value my credibility here. It’s rule #18 on attached photo.
