The ASM belts work fine and I haven't received any concerns with the track groups I run with. I recommend you call Schroth and talk to them directly.
I sit on my two point Schroth sub belt , honestly you never notice.Thanks guys. 06Mach1, how do you deal with there being no slots in the seat? Do you just do the ol' lay them over the front bolster and sit on them? Actually, I can PM you, but thought I'd post here in case anyone else was wondering.
Thanks guys! One more question for those with this roll-bar - Watson has their precut rear seat kit but it appears to use backer boards and in another thread or forum a member weighed it at 13 pounds. Southeast Carbon Works has this carpet-based RSD that looks to basically be a knockoff of the stock RSD, for $200, and weighs 2.5 pounds. Given that it's cheaper and weighs 10 pounds less than the boarded Watson kit, wouldn't that be a better route if I don't mind cutting the holes?
http://www.southeastcarbonworks.com...r-seat-delete-package-for-all-model-mustangs#
The Watson one appears to be a cut version of the Alterum RSD:
https://www.americanmuscle.com/rear-seat-delete-kit-2015.html?utm_content=Interior - Seats|Alterum&utm_campaign=AMM 2015 No Years&utm_source=google-pla&utm_medium=shopping&T5_Var3=blue&T5_Var4=388917&intl=0
Happy holidays!
CMS bar here, so only topside install, no drilling into the trunk pan. No differences from my 350. You will need to keep the rear belt latches (the part in the seats) plugged in to not throw a nuisance code. The rear belt reels can be removed without issue.Any 2020+ GT500 owners do this install? Anything significantly different about it? I’m wondering if spot welds and/or locations are different, or brake lines or other underneath clearance/access issues with the GT500 underbody diffusers / panels, etc.. Thx.
